Thanks for your quick response - I appreciate it. I went back and checked "defined in CSS" and it still doesn't work. Do I need to add anything to the Stylesheet?
I am not happy using the current flash MP3 audio player as it doesn't work on Iphones and I pads. If I try to implement pickle player (http://www.pickleplayer.com/) into my site do you anticipate any problems with that. I thought I would check before I purchased it.
It is not flash player - it is HTML5 or flash depending on device/browser. It works fine on my iPad but not in Spaceship theme:-) Give me some time and I will prepare fix for it.
As previously: I have no idea:-) Sorry for making you wait so long, just had very busy update in last days. Now I will check it(my code) out and post answer with fix later.
Great I found it - one more quick question (sorry but I don't want to mess up any of the work I have done - and messing with directories scares me) - do I replace the current content with your compressed file or just paste it onto what is already there)
Remember to check the "Defined in CSS" option!
Best Daniel
http://codecanyon.net/item/skan-responsive-audio-player-with-playlist/4534475
Best
Unpack this ZIP file and copy compressed.js to
/jsdirectory in theme. This should fix player on iOS. I will also post it as update.With regards.
wp-content/themes/spaceship/jsWith regards.
