trouble with fonts
edited April 2013 in Spaceship Posts: 37
I think I am doing something wrong with Font/ No matter what I change my google fonts in CSS to under the "Titles/Headings" I cannot get it to change.
    Hello Blyth
    Remember to check the "Defined in CSS" option! :)
    Best Daniel
    Lead Graphic Designer
    Thanks for your quick response - I appreciate it.
    I went back and checked "defined in CSS" and it still doesn't work. Do I need to add anything to the Stylesheet?
    What kind of font you wish to use? One form google? If yes, then please follow this process http://apollo13.eu/docs/spaceship/#!/fonts_menu
    Thanks - one more unrelated question.
    I am not happy using the current flash MP3 audio player as it doesn't work on Iphones and I pads. If I try to implement pickle player (http://www.pickleplayer.com/) into my site do you anticipate any problems with that. I thought I would check before I purchased it.
    It is not flash player - it is HTML5 or flash depending on device/browser. It works fine on my iPad but not in Spaceship theme:-) Give me some time and I will prepare fix for it.
    Thanks - no hurry - much appreciated
    If I was to use the following player would it work in spaceship theme and save you some work by not preparing a fix.
    http://codecanyon.net/item/skan-responsive-audio-player-with-playlist/4534475
    edited May 2013 Posts: 10,970
    As previously: I have no idea:-)
    Sorry for making you wait so long, just had very busy update in last days. Now I will check it(my code) out and post answer with fix later.
    Thanks - no big hurry - I just appreciate your help. I am going with this player - (http://www.pickleplayer.com)
    Best
    Unpack this ZIP file and copy compressed.js to /js directory in theme. This should fix player on iOS. I will also post it as update.
    zip
    zip
    compressed.zip
    28K
    Please excuse my ignorance but where do I find the js directory in theme
    I think if you will take a look at your theme on FTP you will have no problem with finding it.
    wp-content/themes/spaceship/js
    Great I found it - one more quick question (sorry but I don't want to mess up any of the work I have done - and messing with directories scares me) - do I replace the current content with your compressed file or just paste it onto what is already there)
    Whatever you will choose to do it is in then end same task:-) If you want to be safe on files operations just backup things you will be changing.
