If possible, I'd like to request the feature of being able to show the subtitle and some introduction text on the blog page (possibly just the text from the page that's used as the blog).
Could you extend your request? Cause now on blog list every post is displayed with: title and text(excerpt or text till "more"). Post don't have subtitles.
I mean a short, static introduction to the blog in general as a subtile to the page - between the title and the blog posts.
We're using our blog mainly as an inspiration catalogue for our design process. It would be nice to have a short text in the style of the subtile on the contact page, for example. Something like:
(title)THE BLOG (subtitle)here we post some of the things that inspire us
OK now it is easier to understand :-) Question is: Do you use Blog as main page or you use separate page for blog? In case of second I would have better option for you, but if it doesn't matter for you this should be also fine:-) Go to advance/utilities.php line~956 and change:
(title)THE BLOG
(blog post 1) (blog post 2) (etc)
Go to
line~956 and change: to: With regards.btw, is there going to be a changelog available for version 1.1?
changelog.txt
in main directory :-)With regards.
