Hey,
1. I wanna use the portfolio-page for showing single pictures (like
http://www.cortis.info/wordpress/?page_id=3819 ), the problem is that the picture will be enlarged and the pictures will lose a lot of quality
2. is there a possibiltiy to sort the pictures by hand ?
regards ben
1) so you need to photos keep thier max width?
2) unfortunately there is no option for that
Best,
Miłosz
2) ok, snief
other 3) is it possible to modify the "small preview" pictures? eg if i have a portrait-format the "small pictures" is been cutted for a landscape-format. not every time the cut is been perfect for the picture.. maybe it´s possible to upload that "small pictures" by hand ?
1) so it needs changes in css file. Can you make it by yourself if I tell you what to change?
3) You can add custom thumbs in work edit panel. I thinks it is the best solution.
Best,
Miłosz
you need to add this code: css file is in the /common/css/skeleton/layout.css.
I hope you will manage to change it.
Sorry for delay in response.
Best,
Miłosz
now i have found the time to test it..
the problem with "auto" is that the picture will be auto scalled to the maximum size of the browser window.
e.g. i have a lot of pictures that are optimized for 750px * 750px, but if i try to use your code on a screen with a high resolution the 750px picture looks enlarged and sh.t ..
is it possibe the set for the autoscale function a max widht for the pictures? so that the picture can seen only with max 750x width and if the browser screen is smaller it will be scalled down ?
you need to add
max-width: 750px;
to this code above.
Best,
Miłosz
also fine with the px-probleme....
but now the picture is fixed on the left side ..is there a way to move it in the middle of the page ?
regards ben
do you still have this problem?
You need to add this code: to the css.
btw the now i have another little problem with my layout..when i wanna view the portfolio by my iphone, the layout is not sized for 100%, it shown be just a little bit smaller..i would guess 60% .. you know what i mean?
it looks like this on the all pages?
Thanks for information, I need to check it carefully.
Best,
Miłosz
I have the same problem as bcor
I only have the problem on the gallery.
Thanks,
Grégoire
the strange thing is that the preview of the template of themeforest works fine...
Thanks.
we are preparing fix to this issue right now. I will let you know as soon as we finish.
Thanks for patience.
Best,
Miłosz
the function "max-width: 1000px;" works fine..but "max-height: 750px;" is not been supported ?
because i just different formats (750/750,1000/600,...) i wish i could combine both limits..eg. to use max-width 1000px and max-height 750px...
The max-height property is supported in all major browsers. It should work with no problem.
position: relative;
display: block;
margin: 0 auto;
max-height: 750px;
that´s my code at the moment...but if u look here:
http://cortis.info/?portfolio=1287 it seems to be ok (the original picture is 1000x667, like here: https://plus.google.com/u/0/photos/102377882249382281108/albums/5629124241541385457/5797951485492490978 )
http://cortis.info/?portfolio=1315 here it´s not working (the original picture is 1000x1000 , like here: https://plus.google.com/u/0/photos/102377882249382281108/albums/5629124241541385457/5786807705971605874 )
http://cortis.info/?portfolio=1308 here it´s also not working (the original picture is 750x750, like here: https://plus.google.com/u/0/photos/102377882249382281108/albums/5629124241541385457/5630933984497706178 )
please send it on support@apollo13.eu.
Best,
Miłosz
the problem is footer menu over photo?
You need to delete: max-height: 750px; from:
a.alpha-scope {
position: relative;
display: block;
margin: 0 auto;
max-height: 750px;
It woks for me on your site.
Let me know if it was your problem.
Best,
Miłosz
i have deleted the "max-height..." again, but now it´s still the problem that i have at the beginning..
e.g.
if u look at that picture on a screen 1680x1050, the 750x750 picture is blown up like a balon...
i just wanna view my pictures not bigger than the original is, it looks not nice that "balon-picture" .. i hope we can find a solution for that in the next days
now should be ok. Please check it and let me know.
Best,
Miosz
in generel it looks better
just a little thing: http://cortis.info/?portfolio=1308 is it possible to move the pictures in the middle of the layout ?
and now i am curious where have to modified the code ?
regards ben
Easiest way to do it is to modify this style in file common/css/skeleton/layout.css: Let me know if this works for you.
Kind regards.
now should be in the middle.
I have to change make_collection function in apollo13.php file. There were inline css code: ''style = "width: 940px;"
I have just delete it.
And to set image in the middle I set:
div.vert-item {
text-align: center;
in css file.
Best regards,
Miłosz
thx a lot .. now its fine and thx for yoru time and your hints where you have changed it...
i hope i don´t get further questions for you
1.i try to set the text under the pictures to the middle of the page..
so i have edited the single-portfolio.php
but it it just works if i view the portfolio (http://cortis.info/?portfolio=1308) with a reduzed window of my browser..if i enlarge the window of my browser it jumps to the left...
2.and another question i try to find out is...
when i click on the big pictures in my portfolio, then a new picture of the picture popups like a viewer..is it possible to deactive that function ?
thx and regards ben
1. Which function of above instructions have you used? I mean this one:
http://support.apollo13.eu/discussion/comment/4469#Comment_4468
or this one:
http://support.apollo13.eu/discussion/comment/4469#Comment_4469
2. Would you like to deactivate this function only in this case or on all cases of your website (galleries, portfolio etc.)?
1. i have used the code that milosz have set.. but this was just for the layout of the pictures. but the description of the pictures are been set in single-portfolio.php with a "text-align: center"
If your want to disable fancybox, you have to edit file common/js/jquery.fancybox.settings.js and change it like example below. For second problem in file commen/js/scripts.js add function like in example below (after line jQuery(document).ready(function($){ ): let me know if it works
With regards
2. works perfect
1. works also fine..no windows is popup.... if i move with my cursor over the picture it still change to that "hand"..is it possible to change this too ?
In file: common/css/skeleton/layout.css about 1538 line you have got declaration of div.fancybox_hover like this: Replace it with this code: let me know if it works
With regards
i have replaced the code, but i think i don´t see a different...
Give me a link and i will see it.
With regards
it code is:
div.fancybox_hover {
display: none;
position: absolute;
and when i move with the cursor over the picture it changes to a hand..
Add it into file common/css/skeleton/layout.css in a.alpha-scope After this change it should look like this let me know if it works
With regards
i have added the code and it seems working..
thx a lot.... now i will continue building my page ...
It's hard to tell which previous changes created this problem.
To fix this the best practice is to create a copy of actual theme and download actual version of Skyfashion or remove all changes.
Try to do this and check if there is the problem.
