Hi staff, REALLY GREAT THEME!
i'm using an anchor like this on my work's pages to let the reading easier.
<a href="#ancora">icon</a>
<a name="ancora">text</a>
I wanted to add a jquery easing transition from the icon to the text and i saw that you just added that easing to every page (the arrow in the lower-left corner that let the user go back to the top of the page)
There is a easy way to add the same effect (that i assume is already included in the theme) to the html anchor i'm using?
maybe with just a little string in the relative jquery file i can attach that effect to every (a href="#text")...(/a) thing?
i'd really appreciate a little help if you can
Thank you very much...
website:
www.bloomcreativeagency.com
We are not using any plugin for this smooth color change :-) But we are making use of CSS transitions.
I believe that if you add such CSS in custom CSS field( http://apollo13.eu/docs/beach/#!/appearance_menu_custom_css ) you will achieve what you wish in most browsers: With regards.
Thank anyway for the answer!
For scrolling we also don't use any plugin, just have simple jQuery animation, so I think you can install any plugin you wish and there shouldn't be any problems:-)
