Sorry; links menu? where is it? i use now custom meta extension to dissappear wordpress link! Bcs other needs in meta widged. But i dont want to use extension for it. Can you help.
But there isnt wordpress link in links menu. It comes by default. how to remove it?
(Note:sorry about link menu but In WordPress 3.5, the Link Manager (which some use to build blogrolls) will be disabled by default. i installed "link manager")
Try this custom CSS:
body.blog .post-info{ display: none; }With regards.How to remove wordpress link from Meta widged?
Probably go To Links Menu. Next time you have new case please start new topic, thanks.
Can you help.
