Remove tag and comments blog page
edited May 2013 in Hypershot Posts: 27
How to remove tags, comments and categories from blog page?
regards
    Hello
    Try this custom CSS:
    body.blog .post-info{ display: none; }
    It worked thanks.
  • edited May 2013 Posts: 27
    Hi.
    How to remove wordpress link from Meta widged?
    Post edited by semih on
    Hello
    Probably go To Links Menu. Next time you have new case please start new topic, thanks.
    Sorry;
    links menu? where is it?
    i use now custom meta extension to dissappear wordpress link! Bcs other needs in meta widged. But i dont want to use extension for it.
    Can you help.
    Check this image:-)
    153 x 196 - 5K
    But there isnt wordpress link in links menu. It comes by default. how to remove it?
    (Note:sorry about link menu but In WordPress 3.5, the Link Manager (which some use to build blogrolls) will be disabled by default. i installed "link manager")
    1224 x 422 - 42K
    581 x 668 - 38K
    This is default wordpress widget. Here you have topic about it http://wordpress.org/support/topic/how-do-i-remove-the-wordpressorg-link-from-my-meta-list?replies=5
