Scrollbar Issue
edited May 2013 in Beach Please Posts: 3
Hi there. Like I mentioned before - an excellent theme. Just having some minor issues with the scrollbar / page length. As you can see from the photos, I've created a gallery to showcase some fan media, but the page expands a lot longer than it needs to be. In another gallery with a lot of photos, there's a lot of blank space before you scroll down right to the end of the page.
Am I making some sense with this? lol
    You know it is hard to tell what is making this blank space without live link. It could be some plugin, or some just minor setting:-)
    Please show live link and then we will know more.
  • No prob. It should be live now.
    www.tribesector4.com
    I can see that some plugin is making bad work and coping query what is making this blank space. I would advise to test witch plugin is making this problem.
  • Thank you! I managed to find the offending plug-in, it was something to do with Jetpack! Thanks again for your help.
    For sure I will have to check why Jetpack is doing this, cause maybe this is issue form our side. Thanks for information!
    I found out what was wrong with Jetpack plugin and our theme. If you download new version of our theme it should be fine now:-)
    http://apollo13.eu/docs/beach/#!/installation_update_update_theme
    Thanks for info and best regards.
