Hi Air,
again me.
I have a password protected album, works fine. But: The password window pops up two times. Did you ever see this happen?
When I scroll over my social buttons, a white shadow appears over them. Any way to get rid of this?
Thanks and regards,
Marcus
So socials or password?:-)
Password - link please and password, may be temporary(you can even create test empty album and don't link it anywhere).
Socials - link and screen shot please.
You know how this works;-)
.socials .visible.hover .slide{About you double password form I know there was topic about it... o there it is http://support.apollo13.eu/discussion/713/pasword-protected-gallery/p1background-color: transparent;
User didn't answer which plugin did this double call for post function, so I couldn't check it. Follow answer I have gave him, and come back to me with name of guilty plugin;-)
I deactivated Jetpack and the problem was gone. Activated Jetpack again and it did not reappear.
It is Jetpack: Once I reconnect to Wordpress.com, the problem is there again.
