I need to know if the titles of the albums that are visible in bricks, can be set such that only the first alphabet is capital and not all. Example. My album name is "Photos" but it shows up as "PHOTOS"
Hi, Thanks that worked. as always great support. thanks . I had few more related query. 1. How to make the same text to be not bold. 2.Also for the short description text which shows up under images if put in "image name" place, id like it to be not bold. 2. Also i would like the footer text to not be full caps. Thanks.
To remove upper case form use this Custom CSS With regards.
Thanks.
1.
.albums .item h2, .albums .brick h2 {2. I think you mean this 3. With regards.font-weight: normal;
2/3. Doesnt seem to work. Here are screenshots -
http://i47.tinypic.com/hwx0l2.jpg
http://i47.tinypic.com/245ca43.jpg
.before#footer. Fixed it, you should also ;-)2. OK i though about different title. Use this
.nyroModalTitle {With regards.font-weight: normal;
How to make post titles to be not CAPITAL letters in Blog page
