So I found exactly what you described to me, through FTP client, within the Skyfashion theme folder.
However, the file Downloaded onto my computer into a non-editable file. How would we actually go about making those edits to the definition? Would we essentially have to edit the original Skyfashion theme that we downloaded, make the changes, then re-upload onto Bluehost cPanel to overwrite?
Do you mean Latest blog posts on main page?
With regards
Firstly in your front-page.php file find line change it in placeholders YOUR WIDTH and YOUR HEIGHT : after that find a file common/css/skeleton/laytout.css and in this file find a definition: And change it to: Let me know if it works
With regards
However I couldn't find the file "after that find a file common/css/skeleton/laytout.css" where the img.latest_blog_post_img definition is found.
You have to do it with FTP client if you want to access this file. It is in your skyfashion theme folder.
With regards
Ok, we will try to make it easier. Install plugin like this http://wordpress.org/extend/plugins/pc-custom-css/ activate it, and next go to Appearance->Custom CSS. There you can insert your custom CSS. If it won't work be sure to set Permalinks like explained here http://support.apollo13.eu/discussion/comment/3831#Comment_3831
Code to insert into plugin: Let me know if it works
With regards
