morfoan said: it doesnt work well.
style.css
/********//* TOP MENU */
/********//* END OF TOP MENU */
Could you describe more what does it mean Maybe some screen shot or live example?
I mean, that it has problem with the third level menus, it makes them not visible.
http://www.c-throu.com/wp2/
Here is an example.
Regards.
You can try to switch to uncompressed styles http://apollo13.eu/docs/hypershot/#!/advance_menu_use_compressed_js_amp_css and then in
style.css
remove all styles for top menu. They are starting in line ~396 with and ends line ~512 with Check if it will help you.With regards.
