I think this theme is very stylish. But there is a problem that kind of ruins it: The amout of space for text in menus and the boxes in the blog for tags and information about comments. If you have long words, they don't fit the boxes and flows over. Take for example the word Samarbetspartners in the menu. It doesn't fit the menubox and flows over the line to the right. Or the word Textproduktion as a tag - also to long. In Swedish "No Comments" is translated into "Inga kommentarer", and the word "kommentarer" also flows over the box.
Is this something that will be changed in the near future? Perhaps the boxes in the blog isn't a good solution, even though it is very nice-looking. And the space in menu could perhaps be a bit longer.
But otherwise, I love this theme.
Best wishes,
Annalena
Thank you for that information.
We need to fix it! It can't be like this.
I will check it and back to you.
Best,
Miłosz
do you have this problem with the newset version?
Best,
Miłosz
/Annalena
We can modify this skin for your website ( i mean send you a couple of css code lines which you will add to your files ). Please send me a link to your www and i will try to fix this.
With regards
/Annalena
1) Menu text flows over the lines when words are long (se picture above).
2) Tags and number of comments have the same problem (se picture above).
3) I would need widgets in ordinary pages, not just in blog, contact, portfolio and footer.
4) The featured picture in blog pages is very small and not left aligned to let the text flow to the right of the picture. (see http://wiseheart.se/essensus-blir-wiseheart/).
With regards,
Annalena
Answers for points1 and 2:
Add his code in your style.css file For points 3 and 4 try to add a link with page. Two links in previous two posts shows me intro page.
With regards
3) http://wiseheart.se/wisepub/viu/
4) http://wiseheart.se/essensus-blir-wiseheart/
I have checked your webpage and there is no changes in sections you mentioned in your question. Have you tryied to add this code? Maybe this code doesn't work?
