link to live site
http://www.veryvisual.nl/wordpress/When i use the wordpress dashboard i get this error....
Warning - /usr/home/deb26984/domains/veryvisual.nl/public_html/wordpress/wp-content/themes/airborn/user is not writable.
I do not know what this means or how to fix it. Most changes wil work anyways but it anoys me that i have an error there. I hope you can help me with this.
I am also curious if you can make a short guide to how one can make the theme exactly as your demo website on themeforest.
And last thing is if i want a client login area as menu item but not as a page how can i make this happen? So you have the word "client login"and when you click it you will be linked directly to another window and page with external client login etc. so you never see a page. how i have it now you open a page where you put a link but this is rather messy.
Hope to hear from you soon.
With kind regards,
Niels Sinke
First thing: Login to your FTP account, go to wp-content/themes/airborn and in properties of user directory(usually right mouse click on dir) you have to set rights to 777, so it will allow write in directory.
Check 'How to Set Permissions' chapter on http://www.columbia.edu/acis/software/winscp/using-winscp.html
About guide: most things are written in docs ( http://apollo13.eu/docs/airborn/ ). If something is unclear, please ask about certain things :-)
Login thing:
I'm not sure what you mean exactly. Firstly check
http://apollo13.eu/docs/airborn/#!/airborn_main_settings 'Login form settings' section. If you wish link to something like this http://themes.apollo13.eu/airborn/wp-admin/ just add custom link with such address.
Hope it helps you.
I also have added the slider with the shortcode with two images
[nivo height="260"] [slide src="http://www.veryvisual.nl/wordpress/wp-content/uploads/2011/slider_01.jpg"] [/slide] [slide src="http://www.veryvisual.nl/wordpress/wp-content/uploads/2011/slider_02.jpg"] [/slide] [/nivo]
but i only get one to show.....
There was some errors in sliders in previous versions, and you seem to be affected by them.
About hello blocks: Did you used editor in Airbron->Hompage look? Use it, and everything should work just fine:-)
Please report back if that resolved your issues:-)
I really have difficulty adding images to the portfolio.
I have added an test image in portfolio and some catogries but i dont see the image and the page portfolio doen not show the portfolio image either.
i have set the frontpage to be a static page and show the portfolio latest.
Hope you can help me.
I also cant get the logo image to be smaller.... even if i upload a smaller image or scale it in the media browser.
It would be a big help if you could post your html code per page from the demo site. This way i can paste it in and hopefully get further.....I also bought another theme and they added a pdf with the code per page as they had it in their demo site. This was a great help to speed things up especially if your not very good in wordpress.
edit: i updated the theme to 1.2.5 and the slider works great now... thnx for this update.
Again same thing, check documentation. It is there to help you :-)
You have to configure portfolio page as said here http://apollo13.eu/docs/airborn/#!/portfolio
About logo: don't depend on Wordpress Media resizing in this matter. Rather resize your logo in some image editor. Best to set its sizes to 190px x 100px(whole image with margins around logo) so it will look good, just as on our demo page.
About demo data: you have good point in what you said. As you can read in documentation, we provide whole demo content as XML file(it is in package you downloaded form ThemeForest), but it may not be convenient to use it by everybody.
We will try to do something about it next update, but meanwhile take this file(http://support.apollo13.eu/uploads/airborn-hp.txt). It contains code of our demo Homepage. It uses shortcode(http://apollo13.eu/docs/airborn/#!/shortcodes) for three columns.
I hope I answered all your questions, cause I'm not sure which one was a question and which was statement ;-) Question marks would be appreciated :-)
