Hi there - I saw the thread about enabling shortcodes in the Album Description field - I would like to enable them in the Photo description field. I tried a couple of things but couldn't get it to work. Do you know how to do this? Thanks!
That is the thread I already referred to - it shows how to put a shortcode in the ALBUM description field, but I need to put it in in the PHOTO description field - so the code referred to in the link above doesn't work for this.
Sure - attached is a screenshot of where I am trying to place a shortcode. It actually seems to get stripped out upon saving because if I go back into edit the Album after saving it, the shortcode has disappeared. Thanks!
webtw said: I made the change referred to in the other topic, although I didn't find that code on line 231, I found it at line 247.
Yes there were some update since that post so it might get shifted. Anyway I have found issue, it was caused by using ". I have fixed it plus added native support for shortcodes in photo/album description.
I think this should come in handy http://support.apollo13.eu/discussion/comment/5957#Comment_5957
[button class="green" url="/"]Press[/button]
Please tell me have you made changes explained in topic I linked before?
and it also got stripped out.
. I have fixed it plus added native support for shortcodes in photo/album description.One more fix and we will release update.
Thanks for help!
Sorry for issues and with regards.
