Hi. I recently changed the following:
Site options: portfolio page: and selected a new page I created for the portfolio page. Everything is working except that the SEO title I entered is pulling from the old page I had set as the portfolio page, not the new one. I cleared my cache, but can't seem to figure out why it isn't showing the correct SEO title. Is there somewhere else I can change this? I viewed the source code and it's still listing the incorrect page information as well, but the content on the page is correct.
The old portfolio page was set as the blog page...not sure if that has anything to do with it.
In addition, this page was added to my header and footer menus, but doesn't stay highlighted when on the page.
Thanks for any help.
Please send me a link to your page.
With regards
What do you have in your "slug" form (i mean short name of this page?)
With regards
With regards
I think that it can not be a problem with skyfashion theme. Please try to change theme to other for a a test and check if you still have this problem.
With regards
Firstly please update Skyfashion to 2.1 version.
I'm currently resolving simmilar issue on this page:
http://www.support.apollo13.eu/discussion/1457/changing-portfolio-slugs#Item_13
With regards
Could you send me login data to your wordpress at private msg?
I will try to resolve this problem from back end of WP.
With regards
Click on my nick, then in left corner "Send Argone a message".
Kind regards
1. Blog sidebar not working on main blog page
2. Portfolio page (press) pulling blog page SEO info as entered in the All in One SEO plugin
3. Can no longer assign Portfolio page in theme options
4. Press page name does not stay highlighted in menu bars when it is selected the way the others do.
5. Blog page pulls short description from Press page (both pages say "as seen in" after the title)
6. The main blog page doesn't list this information at all (Blog | short description)
7. My blog menu option also doesn't highlight when blog post selected
Did you login to my account to take a look at these issues? (resent login info via private message). If none of this can be fixed, I need to know so that I can move on and start using a different theme.
Thank you,
Alison
Ive tested your issue list, and it seems to be checked on our WP instantion.
Check if you can assign Portfolio page in theme options - it was added in our 2.4 skyfashion theme (your 3 point on the list).
3. Press page name does not stay highlighted in menu bars when it is selected the way the others do.
4. The main blog page doesn't list this information at all (Blog | short description)
5. My blog menu option also doesn't highlight when blog post selected
In addition, I've noticed that the footer menu does not work on mobile.
i know that its strange but could you tell me where do you host your wordpress?
Kind regards
About sidebar - please create one revolution slider. We had simillar problem once in past. Creation of it resolved problem of sidebar in blog.
Kind regards
