Hi, I'm doing a simple unordered list, but both firefox (current v21) and IE8 not displaying default left indent? I looked in css, should there be a
#navcontainer ul in layout.css? I'm still learning css, when searching for how to code ul and ol, I found a lot of references to modifying the navcontainer? I found list code in base.css but not sure what I would need to mod. would I add margin-left to this line ul { list-style: none outside; } ? I thought browsers supposed to default indent lists though? I did research this over an hour before asking, if you could help me with default behavior I very much appreciate your time, thank you! -Vicki
oh and this is code section for how I entered list on page:
<h2>Design</h2>
<ul>
<li>Create an Atmosphere</li>
<li>Room Layouts</li>
<li>Accessorize</li>
<li>Art/Photo installation/arrangements</li>
</ul>
Indent in lists are reset. If you like to do this you have to add padding for element 'li' only in content of post/page. For example: Please let me know if it works
With regards
very frustrated here, would not have expected to mod the code for something like bullets for unordered list. pls tell me if shortcodes.css is correct file I need to mod, and which line/ul section. If theme is using ul for front page indenting, then not sure how to get around that. As far as I know, the ul behavior needs to be defined in css file, not in the wp page content, correct??
need a reply this week if possible please, my client is upset and wants to launch and doesn't understand why this is a problem
Use this CSS code in your common/css/skeleton/layout.css file
Kind regards
Little correction:
Kind regards
Thank you, I totally thought this would do it, but still no bullets displaying in browser, I checked both Firefox and Chrome.
It does now display disc bullets in the page edit Visual display, screenshot attached. I made sure to ftp the new layout.css file in binary mode, that is correct yes? and I added this code block into the layout.css file, I didn't replace anything. I don't know why this isn't working, help, thank you!
http://wordpress.org/plugins/my-custom-css/installation/
And catch me on priv msg.
Kind regards
I tried installing the plug-in, but doesn't have option to apply to a particular page, so code creates same front page display problem.
Are you not seeing this when you test it on your demo test site??
I don't understand about the private msg, do you need more info??
thank you
Sorry for long time without answer. I created new WP with fresh skyfashion theme. Then installed plugin as above (http://wordpress.org/plugins/my-custom-css/installation/). Into Plugin window (its available from left menu) i added this code: Result:
http://a13.bboyrudy.com/skyfashion/?page_id=2
Kind regards
