Hello!
i'm having trouble trying to fix some odd behavior on the menu in mobile 640px screen (iphone).
When i click on a item at the menu, it shows de sub-menu.. but then i can't close the submenu... even if i close the whole menu.. when i open again, the sub-menu is still open. IT's supposed to close when i click again, right? or if i open another sub-menu... or even if i close the whole menu and open again. None of them is working.
http://www.museunaif.com - Can you help me fix this?
Thank you
That is why(on touch screens) first click shows submenu and second one acts as normal link. That would be nightmare :-) If above your new, just clicked submenu, will hide old one, it would move all links from place they were before, possibly even off-screen. Well, not necessary. How often user will click menu, show subemnu, then hide menu, and again open menu and will like this time to go to different part of menu. I rather believe that leaving submenu open as it was before user closed menu is better.
But again this is only my opinion:-)
Can you tell me where can i edit the html Menu for mobile, if i want to implement other kind of menu? i can't do it on header.php
advance/utilites.phpline ~712class A13_menu_walker extends Walker_Nav_Menu {With regards.
