Hi there,
I have two questions I am dying to learn:
1. how can i make the container transparent, so that all the content (text,pics etc) lying just blank on the main background i stetted up?
2. how is it possible to set up the first page / homepage with a static page i created (like:about) but I still wanna be able to use the 'latest work' widget plus 'hello text', though I'd prefer to make those sections below my own content?
Any help is appreciated.
Thanks in advance.
for anyone who'd like to know the code:
inside of the common/css/skeleton/layout.css add on top
div#main, #nav li a, div#footer {
background: transparent
but still one question is remaining:
how to let the white container under the menu disappear,
looking forward to hear from the support - thanks!
Please let me know which container would you like to make transparent. Could you send me screenshot with specified element?
Kind regards
thanks for your fast reply. Attached you find the screenshot.
Since I changed the 940px wide box to transparent I would like to do the same with the white container under the menu bar. Would be super helpful if you can tell me where to find the code.
The 2nd question i have is about the landing page. There the theme offers the function to display the 'latest work' bar as well as the welcome text, in my case a quote ( also shown in the screenshot ) Is it possible to move those widgets to another page?
Thanks in advance for your time.
Gunnerson
i understand which element please send me a link. If you dont want to send it in post just send it through private msg.
Latest works you can add through widget so you can add it into placeholder. If you need to move quote - its not possible at all but you can add a widget with text.
Kind regards
http://www.ieatyou.de/
i checked out the widgets but i only see possibilities to add them for blog, portfolio, ect. possible to place them also on default template pages?
thanks for your fast help
About widget... Default template pages you mean front page?
Kind regards
regarding the widgets: my front page will be 'STORY' and in the section 'page attributes' I selected as a template 'default' - means just a simple full width static page. is there any way i can add here the latest work bar or any text widget?
Kind regards
i am coming back to you today cos I am still struggling with the same problem. I would like to skip the general front page (which i did now with the help of an index.html - but i need to erase that one cos it's not compatible with the theme). My aim is to show the page 'About' as a first page, exactly as it is, with a picture and text. just straight when you enter the URL http://www.ieatyou.de. Could you please help me in this matter, i need a quick fix. Thanks in advance - Ina
In Settings->Reading set Front page displays to static page and select your page. Also from theme either remove or rename front-page.php file. You can reanme it by prefixing it with
_
so it looks like _front-page.php.It should help.
