#other-albums
edited October 2013 in Hypershot Posts: 4
Hi Apollo,
I had to convert the #other-albums nav to a drop down since there simply wasn't enough room to display them all at once.
Everything is working smoothly except I can't this line of js to remove the 'current' class. So it will highlight the current album properly and remove the 'current' class once a new album is selected. I suspect it's because I now have the 'a' nested inside the dropdown nav
    edited October 2013 Posts: 10,970
    Sorry for late answer.
    Your siblings doesn't exist:-) as now every a is in li, so it is alone. Code should look like this
                //highlight current album
                $(this).addClass('current').parent().siblings('li').find('a')
                    .removeClass('current');
    Works perfect as expected. Thanks for everything.
