Hi Apollo,
I had to convert the
#other-albums nav to a drop down since there simply wasn't enough room to display them all at once.
Everything is working smoothly except I can't this line of js to remove the 'current' class. So it will highlight the current album properly and remove the 'current' class once a new album is selected. I suspect it's because I now have the 'a' nested inside the dropdown nav
etc.
//highlight current album
$(this).addClass('current')
.siblings('a').removeClass('current');
The addClass still works and inserts .current so in theory I should still be able to remove the .current class with js. Any suggestions?#other-albums menu:
<div id="other-albums" class=""><nav><ul><li> <img src="/images/controlls.png" alt="Portfolio"> Portfolio
<ul><li><a href="/galleries/boston/" data-id="68">Boston</a></li>
<li><a href="/galleries/cape-at-night/" data-id="7">Cape at Night</a></li>
<li><a href="/galleries/cape-impressionism/" data-id="80">Cape Impressionism</a></li>
<li><a href="/galleries/cape-in-winter/" data-id="90">Cape in Winter</a></li>
<li><a href="/galleries/cape-patterns/" data-id="31">Cape Patterns</a></li>
<li><a href="/galleries/cape-seascapes/" data-id="94">Cape Seascapes</a></li>
<li><a href="/galleries/cape-skies/" data-id="100">Cape Skies</a></li>
<li><a href="/galleries/cape-wanderings/" data-id="36">Cape Wanderings</a></li>
<li><a href="/galleries/cape-sunsets/" data-id="103">Cape Sunsets</a></li>
<li><a href="/galleries/cape-wildlife/" data-id="109">Cape Wildlife</a></li>
<li><a href="/galleries/through-the-iphone/" data-id="114">Through the iPhone</a></li>
<li><a href="/galleries/paris/" data-id="45">Paris</a></li>
<li><a href="/galleries/rock-harbor/" data-id="130">Rock Harbor</a></li>
<li><a href="/galleries/tuscany/" data-id="134">Tuscany</a></li></ul></li></ul></nav></div>
Sorry for late answer.
Your
siblingsdoesn't exist:-) as now everyais inli, so it is alone. Code should look like this With regards.
