input[type="submit"], a.a13-button, a.more-link { background-color: #1ABC9C; }
a.menu-button{ background-color: #1ABC9C; }
a.menu-button{ background-color: #6fb400; }
a.menu-button:hover{ background-color: #6fb400; }
This is CSS that controls color of this and others buttons You can change it and add to Custom CSS in theme.
If you want to change only color of that button use this instead:
a.menu-button{With regards.background-color: #1ABC9C;
a.menu-button{when i use the code above it changes the colour of the menu button but the hover colour is still that same…how can i change the hover colour?background-color: #6fb400;
a.menu-button:hover{With regards.background-color: #6fb400;
Please read http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
When you will be starting your topic(s) please show on screen shot what is side bar button.
For footer try footer settings http://apollo13.eu/docs/superior/#!/customize_footer
For scroll to top try searching forum http://support.apollo13.eu/discussion/comment/7524#Comment_7524
