If I switch off the Music Player by selecting the "off" radio select under Music Settings when I click save changes I get a 403 error message:
403 Forbidden
Server configuration does not allow access to this page.
COMMON POSSIBLE REASONS FOR THIS ERROR:
The location you attempted to access has incorrect folder and file permissions set on the server, OR
The page you attempted to access is breaking a security rule, OR
You may have attempted to access something with incorrect credentials, OR
You may have attempted to access something something you do not have permission to.
If you are the webmaster please contact your host.
If you are a visitor please contact this web site owner.
Also is there a way to turn off the info bar above the header or does it disappear if I turn off the search/music and contact options?
You main problem - I would ask your hosting provider, maybe some antivirus software on server is blocking site load.
Second question(Please don't ask more then one question in one topic).
http://support.apollo13.eu/discussion/comment/4135#Comment_4135
