I'm using a plugin to add taxonomy tags to the bottom of the blog posts on my site (www.hey2a.com). When the tags are clicked, they don't seem to sort properly; the page just displays all posts. I'd like only posts assigned to the clicked tag to display.
Standard tags sort just fine. Is there any way to fix this?
1. Plugin name.
2. Does it work on standard theme?
3. Category and Tags that are now available in theme is not enough for your task?
I'm not sure about functionality with other themes, but I hoped it would work just like normal tags.
I need a solution that formats tags differently than this theme allows for. This plugin does the trick, except for the sorting problem.
Could you point me to your site and write what I have to do to see issue you mentioned? Maybe then I will get it:-) Could you explain more what you want?
That plugin created these fields and the field values are added with each post. The values show up as hyperlinks at the bottom of each post. When the tag is clicked, I'd like the posts to sort based on that tag value just as normal tags do. For some reason, this isn't working. When any of the links are clicked, the page just loads all of the posts.
Is there a way to fix this? Thanks for the help!
