Hi Support, i need help with the minor changes. Please suggest about the below changes and solution
on every blog post , posting details appear above the text , is it possible to have these details at the end of the post , like: Date, time, By , posted in, tags etc ( please see the attached screenshot)
And
Is it possible that when user click on article link , currently it leaves that page , can it be changed that user click on article , then it opens in a new window rather than on same window
Lastly,
when i enter the link of website (mainpage) on facebook status to share mainpage with my friends, it automatically pick the picture from one of the post , not from mainpage or not logo .. and also the description from the inside post .. can it be changed ?
opening in new window From point of usability it would be disaster, cause user should have full control if he want or not open new tab/window. But it is your page and you decide what kind of user experience your site provide:-) To do it edit airborn/loop.php search for
about facebook issue sorry, but it is normal facebook behaviour. You could add some stiff info to force facebook take other info, but there is no warranty it would work.
Hi, On the front page and blog page i would like to change to replace the slash of the date by a"." where i can do that? And second need, i would like to replace the word "comments" by an icon?
Hi there
moving posting details
search for
and change it to
search for
change it to
next search for
change to
Regarding New window:
Only working in archieve page , not the whole website , but yes i understand , this is not good for visitors
Is it possible to use the links open in NEW window , only for links in the slider of the hompage
Looking forward for your help on both
Make sure you changed all things I mentioned. It should work on blog page and archive pages. Show me link to live project, so I could see myself.
About sliders you will have to edit file /airborn/advance/shortcodes/sliders.php
search for
change to
next find this
and change to
