Only 12 images in a single gallery
edited December 2013 in Beach Please Posts: 6
I purchased Beach Please, when I create a single gallery only can upload 12 images and no more. When I upload another one is like broke. I've been looking if there's a restriction about the number of images can be upload but i couldn't find it.
Take a look at the attached image.
One other thing is that I can't create a gallery page that links directly to the single gallery. First allways shows the gallery list and then you have to click each gallery to enter it. To solve it I've put the gallery directly through the menu but then the icon image and submenu short description doesn't appear.
http://www.etiktattoo.cat/wordpress/
Please I need help!
Thanks a lot!!
Mark.
    edited December 2013 Posts: 10,970
    Hello
    There is no restriction for images limit. Screen shot doesn't show broken behaviour, last item could be just empty, but it is not enough information to guess.
    I can see you have old version of theme and some plugins installed.
    Please follow this info to try to eliminate issue http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
  • Hi Air,
    Thanks for answer, so I'll update the theme first. But the instructions are a bit confusing... I gotta download again the theme in the download section?
    Coz the version 1.3.1 is announced "Version 1.3.1 (1.10.2013) is ready to download. Check the update status (below)" but can't find it.
    Thnks!!!!
    Mark.
    787 x 173 - 37K
    Yes Get it from ThemeForest and follow this http://apollo13.eu/docs/beach/#!/installation_update_update_theme
    Good luck:-)
  • Hi!
    After updating to 1.3.4 all works perfectly! thanks, but now the popup contact form window disappear ;( Any idea?
    http://www.etiktattoo.cat/wordpress/index.php/contacte/
    Thanks for help!
    Mark
    saikomat said: After updating to 1.3.4 all works perfectly!
    That is great:-)
    saikomat said: now the popup contact form window disappear
    You should start new topic for every new issue, remember:-)
    Anyway I checked you site and I see that it doesn't recognize contact page and don't add proper class to body element.
    It can be caused by some plugin, so test switching off plugins one by one.
  • Hi,
    I switched off the few plugins i have but no results about that. Is possible to put a custom CSS to solve it?
    thanks again,
    Mark.
    saikomat said: Is possible to put a custom CSS to solve it?
    Nope, cause you will end up with other issues if this doesn't work now.
    Could you please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option to send message). In message please attach link to topic it applies to.
    Hi saikomat:-)
    Thanks for data. I have checked your site, and it looks that you accidentally made copy of all templates files in /js directory. Remove from there all *.php files and it should be fine, cause now Wordpress treat them as higher priority, and that causes template names mismatch.
