also, another problem, the weight of submit commentary in the blog miss a part, right now i can only see the Submit commen with nothing else ..... it's quite wired .
Sorry, here's my link to my website: temptdesign.com Actually, its happens only on Safari or Chrome, but Firefox. I don't know why.... and its much worse in Chrome, it can only showoff the night version, and some problem with hello text. The page is loaded in text first, then the entire template. Is there any solution?
Also, i really want to change the font of entire site, is it Arial? I found it very heavy to me, do you have any tutorial that i can try it by myself.
It would be easier to check what is going on if you would post link to your project.
Read: http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
Thx
Find there
form.styled-form input[type="submit"]{and delete width: 124px;-moz-box-shadow: 1px 2px 2px #ccc;
-webkit-box-shadow: 1px 2px 2px #ccc;
text-shadow: 1px 1px 2px #fff;
border: none;
background: url(../gfx/light/submit.png) 0 0 repeat-x;
font-weight: bold;
color: #8e8d8d;
height: 30px;
padding: 7px 17px;
display: inline-block;
margin: 10px 0 0;
width: 124px;
text-align: center;
While you are there you can edit font family, find:
html{end edit font-family property, but remember to use safe web fonts http://www.ampsoft.net/webdesign-l/WindowsMacFonts.htmlbackground-color: #f6f6f6;
font-size: 13px;
color: #a1a1a1;
min-height: 100%;
font-family: Calibri, Arial, Tahoma;
If you have problems with Hello text disable theme switcher http://apollo13.eu/docs/airlock/#!/airlock_main_settings_strongtheme_styles_strong and use only one theme version.
