HI, I'm wanting to add background music to an Album but not have it on all the pages. Is this possible? Or is there a way to add a sound file to an album? Thanks
few post below in the hypershot thread. I gave my probably not perfect solution, and obsolete as I did it with an old release, but just for you to know it might be possible yes but needs little comprehension from wordpress & coding.
Ah, Good thank you. I am newish to wordpress, but I was a web designer/builder for 10 years from the late nineties to 2009. So I know a little php, and I can find stuff that I need, but was hoping someone else maybe had found how to do this, as I don't have a lot of time these days and am on quite heavy pain medication, so it makes me a little foggy. I'm using a child theme, and have adjusted functions.php before, but writing code straight off my back that is another story. So was hoping someone here may have figured it out. Thanks! I hope you can help.
The only point is that I cannot promise update didn't broke my logic (nor line numerotation). But you might figure out how it's working : adding 2 customs var to album page, passing them to the player in JS for the call of the player... sorry I'm probably less skilled than you and it took 24h to have it running so you might succeed with little test and perseverance
