I imported default.po in PoEdit, I typed the strings with localized text, I saved as It_IT.po and copied in hypershot/languages/admin even with the new default.po you sent me, replacing the existing one . but the wp admin menu is not localized.
I made the change but it does not work. I'm sorry if this does not serve the client, I do not insist. I send you my file apollo13.php so you can check if I was wrong to correct it. thank u very much.
sorry for my english, I wanted to say "if it wasn't useful for the customer, I shouldn't insist"
I had set italian language in wp-config.php - define('WPLANG', 'it_IT'); -
I have not installed any localization plugins, i don't need it, the wordpress is already translated and I chose this template because is multilanguage ready through file .po.
I don't know why you don't see translation. I have tested this and it works for me.
Could you please send me temporary access to your WP and FTP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option to send message). In message please attach link to topic it applies to.
Unfortunately, the provider does not support multi ftp accounts. since the domain of my client, I am not authorized to give you the login information. for the wp I have no problems. But I can upload here the files that you want to check.
I wanted to debug what is going on, cause I don't have idea how to help you further, as it works well for me. Maybe some changes didn't save in your working copy of theme. Anyway good luck!
After hour of debugging I found out that while updating theme to 1.5.1 you didn't change file advance/cpt_album.php and there where wrong ways of displaying "My Albums, Album, Add New ".
thank you very much... sorry, but probably when I decided to use child theme instead of modify theme file, I forgot to reset the last updated theme file. now I proceed to translate admin panels. thanks again
just a question: now I want to update the template. Actualy I use a child theme of template, so if I update a file within theme but I use the same file in child-theme folder, read wp the updated file or my "obsolete" child file? or have I to compare the file to update my child file too? and... If I move only IT admin .po file in child folder can I update the template but using my .po file translated. I hope you understand me. tks a lot.
Here you have update language files for admin.
thank you, but don't traslate. I had compiled the localized .po and copied in admin folder, but I show it in english. what about?
advance/apollo13.php
in line ~112 to It will be add also in new version so don't worry:-)With regards.
Anyway good luck!
Now it works fine.
