New problem : i wanted to modifiy the space between two text lines in a h2 paragraph on my home, so i make modification in style.css (see the screenshot).
To explain the screenshot I divided the general property of titles between two part : the first with all the titles h unless the h2, and the second part only with the h2. Like this i would to change only the property of h2 titles (in order to change the space between two text lines))
And it worked ! But just for the space, because i wanted to change the weight in the same time of h2 title (before=bold, i wish now=300 (thin)) and it don't works !
i have tried a lot of things but h2 is still bold. I even try to change all the "bold" in style.css and user.css to "300" but visibly i don't find the good lines...
Have you a better idea ?
Thanks a lot for your precious help
1. You CSS selector is too weak probably.
2. Setting weight of titles you have in Typography -> Headings styles menu.
3. If you still won't make please show me exactly what you would like to edit.
How to do that ?
Thanks a lot !!
Regards, Antoine.
www.portraitdecomediens.fr
I'll tell you if it works
And for the interline spacing, have I to put it too in the custom CSS field ? Or i keep it in style.css ?
With regards,
Antoine
Best regards
