I'm loving the theme and just about ready to go live. I also love the different post types. I'm wondering if under the Blog Post Details options where we can either choose image or audio/video, if there can be an option to add None. This way, my featured image will appear on the blog page but it will not actually appear on the single post itself so that the content can be at the very top instead of the big featured image. This will only apply to the single post since I'd still want the featured image to show up on the blog listings page and blog shortcodes.
Is this possible to include on a future release or is it possible to do now?
Thanks for your help.
Check http://apollo13.eu/docs/superior/#!/blog_menu
1.you want featured image in posts list but not in single post(yes/no).
2.you want video in posts list and in single post(yes/no).
1. Yes
2. Yes
.single-post .item-image.post-media{With regards.display: none;
.single-post .hentry .item-image.post-media{With regards.display: none;
Here's an example: http://alexnavas.com/an/keep-an-open-mind/
This should work(checked):
.single-post .hentry > .item-image.post-media{With regards.display: none;
I went live on the site last night so you can find the post at http://www.alexnavas.com/keep-an-open-mind/
I have just checked and you have old CSS.
