Wonderful template guys... but im missing a few options...
Would be wonderful if you could help...
I tried to attach jpeg and pngs less than 500Kb but i got the message Filetype not allowed... hmmm... (?)
So i leave the site open...
www.silenzia.com
1- Can i have code to give a different color for the "Pause" and "Hide Layout" and "show layout" texts ONLY? I need them to be seen right away...
I couldnt find this in the options and when i css it i get aaall the number sounters, image title and the footer menu in red as well... which is VERY disturbing to the eye
Heres the css which i used...
#footer a, #footer span.action, .glass-switch {
color:red;
Levent
Use this CSS http://support.apollo13.eu/discussion/comment/3142#Comment_3142 but with
color
instead ofdisplay
property :-)With regards.
But listen..
I couldnt get this to work... tried your code in many ways...
first as you suggested... like this (i think..)
#switch-glass, #play-button{
color: red;
nothing..
with Firebug i see that .glass-switch action is shown image1 and
.glass-switch code on the right in firebug effects the "hide layout" when i deactivate for example float:right...
So i dont get it It seems VERY easy... but i dont get it
What do you think?
www.silenzia.com
and THANSK
Please tell me where you added this code?
For custom CSS you can use plugin like this http://wordpress.org/extend/plugins/pc-custom-css/ activate it, and next go to Appearance->Custom CSS. There you can insert your custom CSS. If it won't work be sure to set Permalinks like explained here http://support.apollo13.eu/discussion/comment/3831#Comment_3831
I took all the code from the child theme and put it in the plugin...
here is the screenshot with all the custom css in the plugin... do i have another thats crashing it?
I have a few more i want to ask you in a day or two... i hope you dont mind
We are making a pretty nice site out of your template, arent we?
