I have an issue with admin, I dont know if it is a template problem or a wordpress problem.
I have both the latest wp and theme versions. I am using a child theme option.
I created my site, added my albums etc etc everything was fine. Suddenly I lost the "upload" option from the pages. I cant upload a picture in a album. also the edit page seems like it is a bit our of order, like if there is a js or css error or something.
Here is a capture of how the edit album looks, there is no upload image option.
Any idea why this happens?
thank you
I understand you followed this http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
What is the result when you switch off plugins? Still the same?
I had two plugins activated:
Easy Theme and Plugin Upgrades
WP-Cache.com
I deactivated them and everything is back to normal!
the guilty one seems to be WP-Cache.com
any chache plugin you might now that doesnt "conflict" with the theme?
thank you
Maybe it was some setting in it, or you just have to clear cache manually. I don't use any cache plugins so can't help with choosing other one.
