Thanks for a great theme!
I’m trying to get my logo (in the header) to behave just like yours does on the demo, that is: when viewing the page in fullscreen/maximized window, the logo is hidden, but when gradually decreasing the size of the browser window, the logo suddenly appears.
For me, the logo is either always there or never at all, depending on whether I set a logo in the settings or not. Tried to figure it out by checking out the demo code, but without success. Would you mind sharing the CSS for this?
Thanks again
http://superior.theme.apollo13.eu/
First picture: chrome is maximized, no logo apparent.
Second picture: chrome resized, we have a logo!
If this isn't intended, well... I'd like to make the same mistake on my website too!
Edit: Ah, maybe it got something to do with the extra top bar, the black one that's on top of the menu. But I don't need that bar...
I can't help you with achieving such effect cause it was issue of chrome. Fast fix for it would be such custom CSS I will try to fix today and release update.
Thanks for reporting that, even it wasn't your real desire;-)
Thank you for fixing this desired mistake! Or something like that.
No but seriously, thanks for the CSS. It won't be a problem fixing it, I just needed to know why my site behaved differently than your demo.
/ Tony
- Center header menu, but with option of logo on top or not
- Show/hide logo, independent of other settings (practically same thing as above)
- Have a wide/narrow setting for the header too
Basically some more options for moving the header elements around would be super :-)
Thanks for suggestions:-)
Instead of adding previous style adding this one should fix it
.woocommerce img,.woocommerce-page img{With regards.max-width:none;/* fix nasty style from woocommerce */
