No Save Button
edited March 2014 in Hypershot Posts: 4
Am I viewing this right? should there be save button here
    There is clearly not fully rendered panel. It looks like problem with no albums probably. Try adding at least one album(can be empty).
    I will check it on my installation.
    I have checked and there in such issue without albums. What version of theme you are using?
  • Hi, I have a problem uploading the demo content bec my server doesnt allow me to upload more than 40mb, caould I ask a favor and can you set up the demo pages for me if its not too much to ask. I really like your theme and I want to use it. I can give you my WP access
    Does this post continues same issue? Cause it sounds like it is different case, and you should start new topic for it.
    Anyway:
    We can't do it for you.
    rccipriano said: my server doesnt allow me to upload more than 40mb
    Does it mean you have only 40 MB of free space? Cause xml import file doesn't have such big size.
    If you fail while following this process http://apollo13.eu/docs/hypershot/#!/installing_demo_data
    Then do it again but without checking Download and import file attachments.
