I don't know if it is a theme or a plugin issue, so i hope you will be able to help me,
The white line just under my slide, i don't know why it's appear, and on the next slide, this line move on top of the slide....
http://alainbeyeler.ch/wp-content/uploads/2014/03/slider-issue.tiff
I have no idea what is this line, but probably style of slider you may choose. Hard to say without live example.
So i will send u an access for the site.
It is great you showed image, so I am only trying t explain how to do it better ;-)
I will check what you have send:-)
Thanks for ur help, u'r a master ! It's all fine now !
