I created a custome page for the template by adding
define('WP_USE_THEMES', false);
require('where_wpload-fileis/wp-load.php');
here is how the page looks http://www.skillednursing.net/skilled-nursing-facility/utah/
everything seems to work except that the menu bar and footer are not working properly.
and I installed easy fancybox so that when someone clicks the more information button, an iframe pops up like here http://www.dementiasymptoms.com/dementia-care/california/ but its opening in a new window. please help I have a dead line to meet. Thanks in advance.
If you will clean this file airborn/common/js/ddsmoothmenu.settings.js it should stop making erros, but only if you don't wish to use menu.
Second approach is to check if you set any menu in WP admin -> appearance -> menu
It might be hard to fix it for me, as I don't get all your modifications ;-)
I am using the second approach to get menus on the main navigation.
and i tried removing the file airborn/common/js/ddsmoothmenu.settings.js using ftp but that didn't solve my problem
now the new problem i am facing is the sidebar is also not working on these custom pages. I don't want any thing fancy but something functional on all the pages .. please help
