After the upgrade from 3.8.3 to 3.9 I have the same. The albums list at the front page using bricks doesn't work anymore. For the time being I switched to a single album but I would like to have a solution for this.
You guys also have the problem with the blog looking completely messed up since last WP update? I don’t mean to stress. I read that there will be an update coming soon, but here’s just been talking about the gallery bricks, not about the blog looking strange now. (see attached file)
I made the code changes AIR provided above and it fixed both the "works" page and the blog roll. I would only add that in Beach Please wordpress 3.9 the necessary code is found under appearance/editor/head_scripts_styles.php. Not under advance in the theme menu. Thanks for the quick fix AIR! http://openoceancompany.com/t-shirts/
Hello There, i'm using Beach Please Theme, and I can't update it, once I upload the new zip file, error comes up on wordpress, it said I have to select "upgrade theme" in the drop down menu, but i can't find this menu anywhere...Any toughts?
Fast fix: Go to advance\head_scripts_styles.php
line ~49 change to Line ~68 change to Update will be released in few hours.
(see attached file)
The update in now live, you can download it from the Themeforest!
Best Daniel
Thanks a lot for the quick support.
Kind regards,
Frank
All our themes should already inform about updates. Thanks for your patience:-) Do you have customized theme?:-) Cause in default installation path is same as in Hypershot and other our themes
advance\head_scripts_styles.php.Anyway thanks!
Please follow http://apollo13.eu/docs/beach/#!/installation_update_update_theme and read it carefully :-)
