Right after updating to Wordpress 3.9 the visual composer stopped working. I cannot see anything, nor can I insert media when I update/modify a page. The
I am in a middle of an important project and I need to update certain pages on a daily basis.
Please advice.
Thank you.
Update your theme:-)
What? How? :
http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#Item_1
http://apollo13.eu/docs/superior/#!/installation_update_update_theme
The only thing I did differently was to change the new theme zip name from "themeforest-6212921-superior-responsive-multipurpose-wordpress-theme.zip" to "superior.zip".
The "error" message I get is
"Are you sure you want to do this?
Please try again."
What am I doing wrong?
Please advice.
Thank you.
For example:
The text block, erase spans inside the H1 and remove
too...not happening when i edit directly the code through classic editor, text mode
live example in http://nuevo .linc.es (little bit useless since i edited manually the code but there it is)
Thanks!!
Thanks for info:-)
Im pretty sure tomorrow i will discover some more issues
Do you plan to release an update that cover all this mess anytime soon??
Thanks!!
Show me live link cause this sounds like something is wrong in your installation, too much issues.
After that, i tried upgrading template too but nothing was fixed
I seriously doubt there has been any problem with install since i followed all documentation steps, like in the past and its not the first time that all gets messed up after upgrading, because of visual composer...i thought more people were also having issues with composer
Ill send you a live link and admin access so yo can see it for yourself
Thanks and best regards
