Site:
http://tinyurl.com/l8ob4jb On Latest Wordpress update
Plugins active: Woocommerce and WPBakery Visual Composer
I tried changing the header background through "Appearance">"Editor" at first but even though I changed the color in the Style.css file, Firebug would still display the old color in the page source even after refreshing the site several time. I then tried to add the color through "Fame Theme">"Custom CSS" editor. It did work but it added the css to the User.css file permanently. Now if I edit the color on "Custom CSS" or try to remove it completely, it maintains the black header background and there's no way to edit it besides probably going into the ftp and changing the actual css file.
I can now see that there are ways to edit header backgrounds and fonts through the "Fame Theme" menu. But I still should be able to edit my CSS files if I want to. What could be causing this problem?
Edit:
I even tried downloading the user.css through ftp to erase the old code saved on there, and there was nothing under Custom CSS... So I'm not really sure why the page source is showing something different.
All things you described here are still from same issue with cache. You can't overwrite things that can be changed by panel, cause they will be overwritten by user.css settings anyway. Read this http://apollo13.eu/docs/fame/#!/modification_of_theme_changing_css
Edit: Erased my ftp files and re-installed everything. Works great now!
