[vc_row_inner][vc_column_inner width="1/4"][vc_single_image image="3202" css_animation="appear" border_radius="10" img_link_target="_self" img_size="200x200" alignment="center"][a13_separator position="full_width" type="empty"][a13_hellotext upper_text="Keith Arnold" title_align="align_center" title_size="size_small" lower_text="Teacher"][/vc_column_inner][vc_column_inner width="1/4"][vc_single_image image="3198" css_animation="appear" border_radius="10" img_link_target="_self" img_size="200x200" align="left" alignment="center"][a13_separator position="full_width" type="empty"][a13_hellotext upper_text="Adam Boyle" title_align="align_center" title_size="size_small" lower_text="Teacher"][/vc_column_inner][vc_column_inner width="1/4"][vc_single_image image="3211" css_animation="appear" border_radius="10" img_link_target="_self" img_size="200x200" align="left" alignment="center"][a13_separator position="full_width" type="empty"][a13_hellotext upper_text="Shona Fahy" title_align="align_center" title_size="size_small" lower_text="Teacher"][/vc_column_inner][vc_column_inner width="1/4"][vc_single_image image="3206" css_animation="appear" border_radius="10" img_link_target="_self" img_size="200x200" align="left" alignment="center"][a13_separator position="full_width" type="empty"][a13_hellotext upper_text="Steph Miroux" title_align="align_center" title_size="size_small" lower_text="Teacher"][/vc_column_inner][/vc_row_inner]
Suggestions?It looks like you're new here. If you want to get involved, click one of these buttons!
-In title you write about columns but post is about images - am I missing something?
-Screen shot is from backend and tells nothing to me or I fail at noticing important part :-)
I can see that in your code you have two parms
, but does this affect front end in some way or you are just reporting bonus parameter ? Cause AFAIK it still works:-)Anyway I will remove this new param from newer builder.
I said images in columns, because those are inside rows divided in 4 sections. You dont miss anything, i just wanted to give all data i can to make it easier for you to understand (but with no luck ;D )
Issue was related to images
Screenshot is from backend, because it looked OK in the backend, and messed up on live site Yes, that was the issue, from that visual composer update, the plugin started to add "alignment" instead of "align", so if you modified an item done with a previous version, it would insert the 2 params, but ignoring the "alignment one"
I dont know the actual state of this issue since i managed to put it right with an old local copy of theme and visualcomposer, and copying pasting the code, so i dont need help in here for now
