Tupamaros said: Can you recommend an event manager plugin
Probably they need some small modification or preparation. They should write about it in documentation of plugins. I don't have any experience with such plugins.
i'm using EventOn, found on the marketplace,
works great, translation ready, beach please compatible, lots of customization...
it's not free, but it's a great work.
http://codecanyon.net/item/eventon-wordpress-event-calendar-plugin/1211017
it worth it if you have to manage multiple events (for my example, a theater company with many shows on the road!)
glad if it helps
regards from reunion island.
I’ll check it out.
Cheers from Berlin, Germany.
