Can you recommend an event manager plugin that’s compatible with Beach Please?
edited May 2014 in Beach Please Posts: 111
the headline says it: Can you recommend an event manager plugin that’s compatible with Beach Please?
I just tried "Events Manager" and "Events Organiser". They didn’t work with Beach Please. Both looked like in the attached file.
    Hello
    Probably they need some small modification or preparation. They should write about it in documentation of plugins.
    Tupamaros said: Can you recommend an event manager plugin
    I don't have any experience with such plugins.
    Yes, thanks. I contacted them. Let’s see what they suggest me to do.
  • Hi,
    i'm using EventOn, found on the marketplace,
    works great, translation ready, beach please compatible, lots of customization...
    it's not free, but it's a great work.
    http://codecanyon.net/item/eventon-wordpress-event-calendar-plugin/1211017
    it worth it if you have to manage multiple events (for my example, a theater company with many shows on the road!)
    glad if it helps
    regards from reunion island.
  • edited June 2014 Posts: 111
    Thanks, PalmOlive974!
    I’ll check it out.
    Cheers from Berlin, Germany. :)
    Post edited by Tupamaros on
