Hello, I wasn't able to find this specific question in the documentation or the forum. Is there a way to enable the main menu to drop down when you hover instead of requiring a click to view? I didn't see a setting for it in the Customizer. Thank you in advance.
What do you mean by Drop down? The animation to show the menu? It would be hard to show menu on hover - you would need to hover hidden menu
Please provide example of what do you want to achieve.
you can mark the existence of submenu with 'Submenu/mega menu open icons' in Customizing >> Header settings >> Main Menu.
As for the hover-opening submenu - I need to check and double check it.
In short - not an option :-)
To mark the existence of the submenu, I tried to enable as you specified by enabling the submenu open icons in the Customizing Header Settings, but it doesn't seem to be holding the change. When I enable it and click Save and Publish, the button appears to stay correct, but when I go to the site it does not appear. When I go back into the settings again to look at it, the setting is back to disabled.
Any ideas why?
Could you please provide login credentials to admin panel? Send it via private message.
The very first thing to do for you is to update the FatMoon theme. You're using 1.0.4 version with latest WordPress and it's highly recommended to update to the latest 1.1.5.
All issues should disappear.
I simply enabled Customizing >> Header settings >> Main Menu >> Submenu/mega menu open icons.
Please start new topic and add there link to your site so I could see what is the problem.
Btw. are you sure you have setup your main menu proper like shown here http://apollo13.eu/docs/apollo13_framework_theme/#!/adding_menu
