Hi there,
I experience a very strange issue. Every time I change something to a text block, I lose all my previous adjustments!
So I can edit the text block, save it like it should, watch the adjustment live, but when I edit the next text block it doesn't seem to remember my previous adjustments, and just adjust text block 2... I'm a bit stressed out because I can't work on my site like this!
- I installed the following plugin: Victheme time-line plugin (that should be compatible with visual composor)
- My visual composor needs an update (right now I'm working with Visualcomposer 5.0.1), but I can't seem to update it because it's part of the fatmoon theme, and I need to wait for a general update? (I installed the envato toolkit plugin - i think... check my previous post on that...)
Can you please help me out fast?
Thx!
Anneleen
(the website i'm talking about is: www.cutewebinars.com)
Then disable this plugin, and test again. If it won't help disable other plugins, like explained here http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#debug_issue
If you were able to edit your pages before and now you can't then it have to be something that changed lately.
So I deactived all plugins and reactived them one by one. But once I activate the visual composer, I get the issue. So it can't have anything to do with the new plugin I installed, but is probably a general visual composer glitch. It's a new site, and I had the issues from the very start.
What to do now?
Thx for your help!
Anneleen
Maybe I will take a look?:-)
I have been on your site and I didn't experience any issues with saving text. It can be even viewed on your page. See screen shot also:
Am I missing something about your issue?
So maybe you could give the following a try.
For example: when I go to the page 'performance & development', I can see the text under the title 'GOAL': dit is een test.
But when I want to edit this textblock in visual composer, I don't see this text, but only the standard text. (check attachments)
Every time I make an adjustment, I can see the adjustment live, but when I want to re-adjust something, it didn't remember my text in the editor...
However I have tested it(front-end editor) on your site and indeed it doesn't update. I tried various things, but I have on clue why it doesn't work proper.
Do you have any cache mechanism on your server or maybe you have moved this site from somewhere else?
Is there a chance that you could try again on fresh install?
