I just bought the theme and I have a few queries after going through it. My site is
http://www.lucentframes.com/Here they are.
1. I would like the "follow social icons" part to be at the right side of the screen instead of over the logo. I wud like the logo to be alone in its corner.
2. How do i change the text from "show info" to a custom text like "about us"
3. In mobile views, the navigation menus are under a drop down menu which has a icon. I need the icon to show the word "Menu" instead of the icon. The icon alone doenst feel descriptive.
4. How do i Disable the lazy load feature.
5. How do i change the text on the send button in the contact form options. Id like to change "submit form" to "Send"
6. How can i hide the numbers "1/7" under the images in albums. Here is a screenshot
http://i50.tinypic.com/voafjr.jpg7. I have set my theme to be wide instead of narrow, my social follow icons and copyright text are towards the left of screen, i would like them to be at right edge. So if the copyright text will come to the right, so i guess the pause and hide layout & search button could be at left
8. Also could the hide layout and show layout options be at the same place. right now show layout is at top , it wud be better if its in same place as hide
9. Also i would like external links to open in new tab instead of same.
Thats it for now
Thank You.
As you have some many requests, then it looks like deeper theme customization, which we don't do(free or paid) as we don't have time and man power for that.
You should also divide your questions to different posts, so other users may also use this answers. Also comment about lazy load you should put in lazy load discussion, not here:-) I will copy it to proper discussion and answer there.
I will however answer on some your questions:-)
2, 5. You can change texts in language file. Edit default.po as explained here http://apollo13.eu/docs/hypershot/#!/translating_theme or create your own language file.
3. There is no need to add word for icon as it is common web pattern and users recognize it very well, read more http://mobile.smashingmagazine.com/2012/10/08/the-semantic-responsive-design-navicon/ . Also there is added 'Main Menu' text for screen readers so most users should be safe ;-)
4. http://support.apollo13.eu/discussion/657/lazy-load#Item_2
6. Add custom CSS 1, 7, 8, 9: Deep theme customization. It doesn't mean this points are very hard to do, but that such changes are unsafe to do, for many factors(like responsive design) and would need additional testing.
Also i was hoping if i could find a solution for my query number 9. I plan to add links to my other websites on my header, but i would like the site to open in a new tab. I dont need this functionality on whole site, but just on header where i plan to add links next to the navigation items. If its not too much of a task kindly help out with the same.
Thanks.
there were two default.po files, one in languages and other in languages/admin.
I edited the one in only in languages. http://www.lucentframes.com/
I have attached the contents of the po file in a txt format. Please go thru and
Kindly let me know whr im going wrong.
My edits are for the show info, hide info, & submit form text
Just found it here http://wordpress.org/support/topic/add-target-element-to-menu-editor I have checked - it works ;-) You have to do it in Menus menu
Languages:
Have you did it by poedit program? What is your language set in
wp-config.php
(check here to answer me http://apollo13.eu/docs/hypershot/#!/translating_theme ) ?With regards.
For the languages, i was doing it wrong, editing the default.po and save it as it is. I saved it as en_EN & then went to wp config & added en _EN & it worked.
