Testimonials Not Rotating
edited January 2015 in Chillout Posts: 4
Hi, basically the testimonials section is not rotating when the window width is higher than 1102px. Attached a screenshot of how the testimonials appears on desktop view.
    please send me an url to your site.
    Hi, sent you a PM with the URL
    please edit shortcode and set 'Rows of items per slide' parameter to '0'.
    Nonetheless I've found some other bugs of testimonials while trying to find what could be the issue that You've reported, but the bug reveals only when You have more than one carousel on tha same page.
    This bug will be fixed in the upcoming update, I'll inform You when it's ready.
    Thanks! That worked.
    Hi!
    I have the same problem, but surgeon- your solution is not working...
    Do you have any idea why? my site url is: www.architectsoflight.4ek.pl
    Yes, but your case is something different.
    please refer to: http://support.apollo13.eu/discussion/3022/problem-with-client-list-people-arrows-not-displaying#Item_4
    more on this case - You should not use shortcodes: 'Media Grid', 'Post Grid','Masonry Media Grid', 'Post Masonry Grid' even inside the posts that are displayed on homepage with shortcode 'Latest posts'.
    You can use those shortcodes, but You can't mix them with 'People' shortcode that we've created.
    p.s. next time create separate thread.
