Hi, basically the testimonials section is not rotating when the window width is higher than 1102px. Attached a screenshot of how the testimonials appears on desktop view.
Hi, please edit shortcode and set 'Rows of items per slide' parameter to '0'. Nonetheless I've found some other bugs of testimonials while trying to find what could be the issue that You've reported, but the bug reveals only when You have more than one carousel on tha same page. This bug will be fixed in the upcoming update, I'll inform You when it's ready.
more on this case - You should not use shortcodes: 'Media Grid', 'Post Grid','Masonry Media Grid', 'Post Masonry Grid' even inside the posts that are displayed on homepage with shortcode 'Latest posts'. You can use those shortcodes, but You can't mix them with 'People' shortcode that we've created. p.s. next time create separate thread.
please send me an url to your site.
I have the same problem, but surgeon- your solution is not working...
Do you have any idea why? my site url is: www.architectsoflight.4ek.pl
Yes, but your case is something different.
please refer to: http://support.apollo13.eu/discussion/3022/problem-with-client-list-people-arrows-not-displaying#Item_4
