Me again.
Got several questions about the blog features. In detail:
- Is there anywhere a breadcrumb for the blogpost? Like in the shop.
- Can I display (in a blogpost) the whole blogpost image as a full screen image? Like the album slider. But to have the ability to scrol down to the post text itself (which stays "centered")
- Is there a way to include the JQuery lightSlider in the theme? Or is there a way to embed a gallery (incl. thumbs) in a blogpost?
- If I "Display post intro on image" and "Empty space in top", the image stays aligned on top. It would look better, if it "crops" centered from the middle.
- Is there a way to show the post titles with all information centered in the middle of a blogpost in the blog list.
.posts-list .bricks-frame .formatter {Nope. Depends on needs. Use this custom CSS for it:text-align: center;
.on-image {With kind regards.background-position: 50% 50%;
Q: Is there a way to show the post titles with all information centered in the middle of a blogpost in the blog list.
A: Nope. You can only add text align center:
text-align: center;
I added a negative "top" value to it so that the whole area seems to be centered on the image.
.bricks-frame .on-image .formatter {
top: -170px;
text-align: center;
In addition to that I add this to the CSS so that the abstract will center too:
.bricks-frame .on-image .formatter .real-content > p:first-child{
text-align: center;
Q: If I "Display post intro on image" and "Empty space in top", the image stays aligned on top. It would look better, if it "crops" centered from the middle.
A: Depends on needs. Use this custom CSS for it:
.on-image {
And this one works great!
If you have a solution for the other ones, please give me a hint
http://support.apollo13.eu/discussion/12/before-you-ask-read-this-#general_rules point 3
Good "this" works for you :-)
Tried to structure it a little bit
