Hello Dear Air - Hope you are doing well. I've just added Google and Yelp Reviews to my Hidden Sidebar and would love to have a G+ Icon there instead so the user will understand why to click it. Can I do this with some little bit of custom CSS code? - Love, Jake from Chicago www.jakemillerphoto.com
CSS code, possible but too much complications. Better do it in code:
Go to photon-a13\advance\utilities\header.php line ~113 to With kind regards.
About rest of your post, this button have many restrictions so putting there image wont happen without modifications that would require much testing after it.
About luring people to find there reviews - if they are really so crucial for you I wouldn't put them in hidden sidebar, but on separate page. This way you wouldn't have to reinvent the wheel ane people that want to see them will find link in menu.
I will ask Daniel opinion also.
